SegmentPerPolyline property example
Sub SegmentPerPolyline_Example()
     Dim iCurrentNumSegs As Integer
     Dim iNewNumSegs As Integer
     iCurrentNumSegs = ThisDrawing.preferences.SegmentPerPolyline
     MsgBox "The SegmentPerPolyline property is: " & iCurrentNumSegs
     iNewNumSegs = InputBox("New value for number of segments per polyline:")
     ThisDrawing.preferences.SegmentPerPolyline = iNewNumSegs
     MsgBox "The SegmentPerPolyline property is: " & ThisDrawing.preferences.SegmentPerPolyline
     MsgBox "Resetting the SegmentPerPolyline property to: " & iCurrentNumSegs
     ThisDrawing.preferences.SegmentPerPolyline = iCurrentNumSegs
End Sub
| ©  Bricsys NV. All rights reserved. |
