Extended AutoLISP Functions
BricsCAD LISP provides some
extensions for standard AutoLISP functions, to give developers more
flexibility and functionality;
those extensions are backward-compatible, to
allow unified client Lisp code to run on both CAD
systems
(naturally, running under AutoCAD, result
values could be NIL, or input is ignored; so client Lisp code needs
to be prepared for slightly different behaviour).
Actually, the following LISP functions provide
extended functionality :
