IAcSmNamedAcDbObjectReference
The interface for a "named" AcDbObject object.
available methods :
(setq cad (vlax-get-acad-object))
(setq ssmgr (vla-GetInterfaceObject cad "BricscadSm.AcSmSheetSetMgr"))
(setq smdb (vlax-invoke-method ssmgr 'OpenDatabase dstfile))
(setq sheetset (vlax-invoke-method smdb 'GetSheetSet))
(setq dwtLayout (vlax-invoke-method sheetset 'GetDefDwtLayout))
SetName
assigns a new name for the referenced object
(vlax-invoke-method sheetset 'SetName "OtherName")
HRESULT SetName ([in] BSTR name)
GetName
returns the name of the referenced object
(setq name (vlax-invoke-method sheetset 'GetName))
HRESULT GetName ([out, retval] BSTR* pName)
SetOwnerAcDbHandle
assigns the AcDbHandle (as a string) of the owning AcDbObject; needed since the name by itself does not provide enough information about the nature of the referenced AcDbObject
(vlax-invoke-method dwtLayout 'SetOwnerAcDbHandle "1A3")
HRESULT SetOwnerAcDbHandle ([in] BSTR handle)
GetOwnerAcDbHandle
returns the AcDbHandle (as a string) of the parent AcDbObject of the referenced object
(setq res (vlax-invoke-method dwtLayout 'GetOwnerAcDbHandle))
HRESULT GetOwnerAcDbHandle ([out, retval] BSTR* pHandle)
©  Bricsys NV. All rights reserved.
