AddArc method
Creates a new arc object and adds it to the drawing.
Syntax
objectVariable = object.AddArc(Center, Radius, StartAngle, EndAngle)
Where:
     objectVariable is an AcadArc object;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Center is a Variant representing the center of the arc;
     Radius is a double-precision variable or number representing the radius of the arc;
     StartAngle and EndAngle are double-precision variables or numbers representing the starting and ending angles (in Radians) of the arc.
Examples...
AddArc method example
