Sub AddCylinder_Example() ' This example adds a cone to the drawing using the AddCylinder method. Dim cylObj As Acad3DSolid Dim Pt1(0 To 2) As Double: Pt1(0) = 5: Pt1(1) = 5: Pt1(2) = 0 Set cylObj = ThisDrawing.ModelSpace.AddCylinder(Pt1, 3, 5) cylObj.Update ThisDrawing.Application.ZoomExtents End Sub
© Bricsys NV. All rights reserved. |
