AddDimRadial method
Adds a Radius dimension object.
Syntax
objectVariable = object.AddDimRadial(Center, ChordPoint, LeaderLength)
Where:
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     Center is a Variant identifying the center point on the arc;
     ChordPoint is a Variant identifying the point on the circle or arc to attach the leader line;
     LeaderLength is a double-precision variable specifying the length from the ChordPoint to the annotation text or dogleg.
