AddEllipse method example
Sub AddEllipseExample()
' This example creates an ellipse and adds it to the drawing using the
' AddEllipse method.
    Dim ctrPt(0 To 2) As Double: ctrPt(0) = 3: ctrPt(1) = 4: ctrPt(2) = 0
    Dim majAxis(0 To 2) As Double: majAxis(0) = 10: majAxis(1) = 20: majAxis(2) = 0
    Dim dRatio As Double: dRatio = 0.3
    'Add the ellipse to the .dwg
    Dim myEllipse As AcadEllipse
    Set myEllipse = ThisDrawing.ModelSpace.AddEllipse(ctrPt, majAxis, dRatio)
    ' Display the entity
    myEllipse.Update
    ThisDrawing.Application.ZoomExtents
    MsgBox "Ellipse created w/ major/minor axis ratio of " & dRatio
End Sub
