AddHatch method
Creates a new hatch object and adds it to the drawing.
Syntax
objectVariable = object.AddHatch(PatternType , PatternName, Associativity , [HatchObjectType])
Where:
     objectVariable is a AcadHatch object;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     PatternType is a Long integer representing one of the following HatchType constants:
acHatchPatternTypePreDefined = 1
acHatchPatternTypeUserDefined = 0
acHatchPatternTypeCustomDefined = 2
     PatternName is a String representing the name of the hatch pattern to be used.
     Associativity Boolean whether or not the hatch is associative;
Examples...
AddHatch method example
