AddMtext method
Creates an Mtext (multi-line text) object and adds it to the drawing.
Syntax
objectVariable = object.AddMtext(InsertionPoint, Width, Text)
Where:
     objectVariable is an AcadMtext object;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     InsertionPoint is a Variant representing the location to insert the text;
     Width is a double-precision variable or number representing the width of the bounding box;
     Text is a String representing the text to appear in the window.
Examples...
AddMtext method example
