AddText method
Creates a text object and adds it to the drawing.
Syntax
objectVariable = object.AddText(TextString, InsertionPoint, Height)
Where:
     objectVariable is an AcadText object;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     TextString is a String representing the text to place in the drawing;
     InsertionPoint is a Point object representing the location to insert the text;
     Height is a double-precision variable or number representing the height of the text.
Examples...
AddText method example
