Converts an angle to a string.
Syntax
Where:
object is the Utility object;
Angle is a double-precision variable (or value) representing an angle;
Unit is one of the following AngleUnits from which the angle will be converted:
acDegreeMinuteSeconds = 1
acDegrees = 0
acGrads = 2
acRadians = 3
acSurveyorUnits = 4
Precision is a Long integer variable (or value) representing the number of decimal places for the angle.
© Bricsys NV. All rights reserved. |
