Display method example
Sub DisplayMethod_Example()
    ' This example creates a paper space viewport and makes it active.
    Dim newPViewport As AcadPViewport
    Dim centerPoint(0 To 2) As Double
    Dim height As Double
    Dim width As Double
    height = 30#
    width = 40#
    centerPoint(0) = 30#: centerPoint(1) = 30#: centerPoint(2) = 0#
    ' Create a paper space Viewport object
    ThisDrawing.ActiveSpace = acPaperSpace
    Set newPViewport = ThisDrawing.PaperSpace.AddPViewport(centerPoint, width, height)
    ZoomAll
    newPViewport.Display True
    ' Before making a pViewport active,
    ' the mspace property needs to be True
    ThisDrawing.MSpace = True
    ThisDrawing.ActivePViewport = newPViewport
    ThisDrawing.Regen (acAllViewports)
End Sub
