Sub GetSnapSpacing_Example() ' This example finds the current Snap spacing. ' First, find the current active viewport Dim viewportObj As AcadViewport Dim XSnap As Double Dim YSnap As Double Set viewportObj = ThisDrawing.ActiveViewport ' Turn on Snap and reset the viewport. viewportObj.SnapOn = True ThisDrawing.ActiveViewport = viewportObj ' Find the current Snap spacing viewportObj.GetSnapSpacing XSnap, YSnap MsgBox "X Snap Spacing = " & XSnap & " Y Snap Spacing = " & YSnap End Sub
© Bricsys NV. All rights reserved. |
