InsertBlock method
Adds a new Block Insert object.
Syntax
objectVariable = object.InsertBlock([InsertionPoint], BlockName, [XScale], [YScale], [ZScale], [Rotation])
Where:
     InsertionPoint is a Variant representing the point at which the block will be inserted;
     object is one of the ModelSpace or PaperSpace collection objects or a Block object;
     BlockName is a string representing the name of the block;
     XScale, YScale, and ZScale are double-precision variables (or values) representing the scaling factors for the drawing along each coordinate plane;
     Rotation is a double-precision variable (or value) representing the rotation angle (in radians) for the external reference.
Examples...
InsertBlock method example
