Mirror3D method example
Sub Mirror3D_Example()
' This example creates a box in model space, and mirrors the box about a plane.
    Dim boxObj As Acad3DSolid
    Dim length As Double, width As Double, height As Double
    Dim center(0 To 2) As Double
    ' Add the box
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
    ' Define the mirroring plane with three points
    Dim ptMirr1(0 To 2) As Double
    Dim ptMirr2(0 To 2) As Double
    Dim ptMirr3(0 To 2) As Double
    ptMirr1(0) = 1.25: ptMirr1(1) = 0: ptMirr1(2) = 0
    ptMirr2(0) = 1.25: ptMirr2(1) = 2: ptMirr2(2) = 0
    ptMirr3(0) = 1.25: ptMirr3(1) = 2: ptMirr3(2) = 2
    ' Mirror the box
    Dim mirrorBoxObj As Acad3DSolid
    Set mirrorBoxObj = boxObj.Mirror3D(ptMirr1, ptMirr2, ptMirr3)
    ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.Direction = NewDirection
    ThisDrawing.Application.ZoomExtents
End Sub
