PlotToDevice example
Following example sends a plot of the current drawing to the default device for your system.
Sub Example_PlotToDevice()
    ThisDrawing.Plot.PlotToDevice
End Sub
Following  example sends a plot of the current drawing  to the a named plot configuration as found in the Roaming directory PlotConfig
Sub Example_PlotToDeviceNamed()
    ThisDrawing.Plot.PlotToDevice ("PdfCreator.pc3")
End Sub
