SaveAs method
Saves the document to a different name.
Syntax
object.SaveAs FileName, FileType [, SecurityParams]
Where:
Object Document
Filename String.The full path and new file name, or valid URL address, for the file. The active document takes on the new name.
FileType [optional] AcSaveAsType
Examples...
SaveAs method example
