Creates a variant that contains an array of typed arguments
Syntax
Where:
VarArr is the name of the variant (should be declared as Variant previously)
Type Visual Basic 6 Constant; The type of values you are supplying: vbBoolean, vbInteger, vbLong, vbSingle, or vbDouble. ;
Value1, value2,...valueN The value(s) to be included in the variant. Must be the type specified in the Type parameter above;
Examples ...
CreateTypedArray method example
© Bricsys NV. All rights reserved. |
