Zoom methods examples
Private Sub ZoomMethodExamples()
Dim scalefactor As Double
Dim scaletype As AcZoomScaleType
Dim PtStart(0 To 2) As Double
Dim PtEnd(0 To 2) As Double
PtStart(0) = 0: PtStart(1) = 0: PtStart(1) = 0
PtEnd(0) = 4: PtEnd(1) = 3: PtEnd(2) = 0
Call ThisDrawing.ModelSpace.AddLine(PtStart, PtEnd)
PtStart(0) = 40: PtStart(1) = 30: PtStart(2) = 0
PtEnd(0) = 44: PtEnd(1) = 33: PtEnd(2) = 0
MsgBox "Perform a ZoomAll", , "Zoom Method Examples"
ZoomAll
MsgBox "Perform a ZoomCenter using:" & vbCrLf & _
"Center 22, 16.5, 0" & vbCrLf & _
"Magnification: 10", , "Zoom Method Examples"
Dim PtCenter(0 To 2) As Double
Dim magnification As Double
PtCenter(0) = 22: PtCenter(1) = 16.5: PtCenter(2) = 0
magnification = 10
ZoomCenter PtCenter, magnification
MsgBox "Perform a ZoomExtents", , "Zoom Method Examples"
ZoomExtents
MsgBox "Perform a ZoomScaled using:" & vbCrLf & _
"Scale Type: acZoomScaledRelative" & vbCrLf & _
"Scale Factor: 6", , "Zoom Method Examples"
scalefactor = 6
scaletype = acZoomScaledRelative
ZoomScaled scalefactor, scaletype
MsgBox "Perform a ZoomWindow using the following coordinates:" & vbCrLf & _
"-10,-10,0" & vbCrLf & _
"50,40,0", , "Zoom Method Examples"
Dim Pt1(0 To 2) As Double
Dim Pt2(0 To 2) As Double
Pt1(0) = -10: Pt1(1) = -10: Pt1(2) = 0
Pt2(0) = 50: Pt2(1) = 40: Pt2(2) = 0
ZoomWindow Pt1, Pt2
"Scale Factor: 5", , "Zoom Method Examples"
scalefactor = 5
MsgBox "Perform a ZoomPickWindow", , "Zoom Method Examples"
ZoomPickWindow
End Sub
© Bricsys NV. All rights reserved. |
