Sub ApplicationProp_Example() 'The following example demonstrates how to return the Application property. Dim myObject As AcadApplication Set myObject = ThisDrawing.Application MsgBox ("Application is: " & myObject.Name) End Sub
© Bricsys NV. All rights reserved. |
