Center property example
Sub Center_Example()
' This example adds an arc to the drawing and returns the area & radius.
    Dim myArc As AcadArc
    Dim cenPt(0 To 2) As Double
    cenPt(0) = 4: cenPt(1) = 2: cenPt(2) = 0
    'Add the arc to the .dwg
    Set myArc = ThisDrawing.ModelSpace.AddArc(cenPt, 3.52, 1, 3)
    Dim getCenPt As Variant
    getCenPt = myArc.Center
    MsgBox "The center point of the arc is" _
    & Chr(13) & "x = " & getCenPt(0) _
    & Chr(13) & "y = " & getCenPt(1) _
    & Chr(13) & "z = " & getCenPt(2)
End Sub
