Sub Count_Example() ' This example demonstrates how to count the number of entities using ' the Count property. It also uses the Item property to return the ' next-to-last entity and change the color of this entity. Dim ents As Object Dim ent As AcadEntity Dim ct As Long Set ents = ActiveDocument.ModelSpace ct = ents.count MsgBox "No. of entities = " & ct Set ent = ents.Item(ct - 1) MsgBox "Color of this entity is now: " & ent.Color ent.Color = 3 MsgBox "Color of this entity has been changed to: " & ent.Color ent.Update End Sub
© Bricsys NV. All rights reserved. |
