Documents property example
Sub Documents_Example()
' This example obtains a reference to the Documents collection
' and displays information about the loaded documents.
    Dim thisDocument As AcadDocument
    Dim allDocuments As AcadDocuments
    Set allDocuments = ThisDrawing.Application.Documents
    Dim sBuf As String: sBuf = vbCrLf
    For Each thisDocument In allDocuments
        sBuf = sBuf & thisDocument.Name & vbCrLf
    Next
    If allDocuments.count > 0 Then
        MsgBox "The loaded documents are: " & sBuf
    Else
        MsgBox "There are no loaded documents!"
    End If
End Sub
