LineType property
Sets or returns the linetype of an entity. The default linetype is the linetype of the layer (BYLAYER).
Applies to All Drawing objects, AttributeReference, Group or Layer
Syntax
stringVariable = object.Linetype
object.Linetype = <string>
Where:
     stringVariable is a variable for storing the linetype name.
     object is the applicable entity object;
     string is the name of a linetype to be assigned to an entity.
Examples...
LineType property example
