Sub LinetypeScale_Example() 'This example returns the LinetypeScale property. Dim ents As Object Dim ent As Object Dim ct As Long Set ents = ActiveDocument.ModelSpace ct = ents.count Set ent = ents.Item(ct - 1) MsgBox "The LinetypeScale property for the last entity is: " & ent.LinetypeScale End Sub
