Sets or returns the oblique angle (in Radians) , which defines the object's "slant" away from its vertical axis.
Syntax
where:
doubleVariable is a double-precision variable (or value) representing the ObliqueAngle property.
object is one of the objects that has a Rotation property: Attribute, AttributeReference, Shape, Text, TextStyle
Examples...
© Bricsys NV. All rights reserved. |
