OwnerID property example
Sub OwnerID_Example()
' This example adds a circle to the drawing and then finds the OwnerID for the object.
    Dim cenPt(0 To 2) As Double: cenPt(0) = 4: cenPt(1) = 2: cenPt(2) = 0
    Dim dRadius As Double: dRadius = 2.5
    'Add the arc to the .dwg
    Dim myCircle As AcadCircle
    Set myCircle = ThisDrawing.ModelSpace.AddCircle(cenPt, dRadius)
    ZoomAll
    MsgBox "The OwnerID for the Circle object is: " & myCircle.OwnerID
End Sub
