Saved property
Specifies whether the document contains any unsaved changes
TRUE: The document has no unsaved changes.
FALSE: The document has unsaved changes.
Syntax
BooleanVariable = object.Saved
Where:
     BooleanVariable is a variable (True or False) specifying whether or not the document has any unsaved changes.
     object is the Document object.
Examples...
Saved property example
