Units property
Sets or returns  the native units of measure for the block.
Syntax
integerVariable = object.Units
object.Units = <integer>
Where:
     integerVariable is a variable (or the constant itself) represents the AcInsertUnits.
     object is the Block object.
Insert Units Constant
Index Value
Index Value
acInsertUnitsUnitless
0
acInsertUnitsAngstroms
11
acInsertUnitsInches
1
acInsertUnitsNanometers
12
acInsertUnitsFeet
2
acInsertUnitsMicrons
13
acInsertUnitsMiles
3
acInsertUnitsDecimeters
14
acInsertUnitsMillimeters
4
acInsertUnitsDecameters
15
acInsertUnitsCentimeters
5
acInsertUnitsHectometers
16
acInsertUnitsMeters
6
acInsertUnitsGigameters
17
acInsertUnitsKilometers
7
acInsertUnitsAstronomicalUnits
18
acInsertUnitsMicroinches
8
acInsertUnitsLightYears
19
acInsertUnitsMils
9
acInsertUnitsParsecs
20
acInsertUnitsYards
10
