WindowTop property example
Sub WindowTop_Example()
' This example finds the WindowTop of the Application window. It then
' increments that position and then resets it.
    Dim iWindowTop As Integer
    iWindowTop = ThisDrawing.Application.WindowTop
    MsgBox ("Current value of WindowTop is : " & iWindowTop)
    ' Increment the value of WindowTop
    ThisDrawing.Application.WindowTop = iWindowTop + 50
    MsgBox "The new value of WindowTop is " & ThisDrawing.Application.WindowTop
    ' Reset original value of WindowTop
    MsgBox "The value of WindowTop has been reset to " & ThisDrawing.Application.WindowTop
End Sub
