Drawing Lines
A line is defined by its starting and ending point. You can create lines by specifying starting and ending points, and define certain properties such as color, linetype, and layer. To create new lines, use one of the following methods:
AddLine
Creates a line passing through two points and adds it to the drawing.
AddXlline
Creates an infinite line passing through two points and adds it to the drawing.
Examples
AddXLine Method Example
AddLine Method Example
