bim:set-spacenumber
(bim:set-spacenumber  entity
 numberString)
Assigns a new numberString number string to
the specified BIM "Space" entity.
| Arguments | entity  any entity (as normal entity or as VLA object name)
to get the number string for (if it is a BIM "Space"
entity) |
| Return | string or NIL, if not a "Space" entity |
| Example | (bim:set-spacenumber ent "My
Space 2")  T |
| Remarks | if an empty string is assigned, the "number string" will be reset to the the BIM default string |
