.NET API
Pro or higher
The BricsCAD .NET API exposes BricsCAD functionality for use by managed code built on the .NET Common
Language Runtime (CLR) platform.
Runtime
BricsCAD V22 uses .NET Framework version 4.8. Visual Studio 2019 or later (including Visual Studio
Community Edition) is recommended for .NET plugin development.
Existing modules compiled for older BricsCAD versions should continue to work unless version-dependent
P/invoke signatures were used to access unmanaged API functions.
.NET project setup in Visual Studio
Create a class library using the class library wizard under your preferred .NET language. Reference the
two required assemblies (BrxMgd.dll and TD_Mgd.dll).
Reference the optional BREP API (TD_MgdBrep.dll) and/or 2d constraints API
(TD_MgdDbConstraints.dll) if needed. These DLLs are located in your BricsCAD
installation folder.
When referencing the managed assemblies, it is important to set the 'Copy
Local' property to False.
Importing the BricsCAD and Teigha COM type libraries with TlbImp
works best without the /strictref option.
Sample projects are installed along with BricsCAD in subfolder \API\dotNet.
Code compatibility
It is generally possible to use the same source code to build assemblies targeting both BricsCAD and
AutoCAD. A common technique for resolving differences in namespaces is to use short namespace
aliases that resolve differently depending on the target application platform:
C#
VB.NET
#if BRX_APP
using _AcAp = Bricscad.ApplicationServices;
using _AcBr = Teigha.BoundaryRepresentation;
using _AcCm = Teigha.Colors;
using _AcDb = Teigha.DatabaseServices;
using _AcEd = Bricscad.EditorInput;
using _AcGe = Teigha.Geometry;
using _AcGi = Teigha.GraphicsInterface;
using _AcGs = Teigha.GraphicsSystem;
using _AcGsk = Bricscad.GraphicsSystem;
using _AcPl = Bricscad.PlottingServices;
using _AcBrx = Bricscad.Runtime;
using _AcTrx = Teigha.Runtime;
using _AcWnd = Bricscad.Windows;
using _AdWnd = Bricscad.Windows;
using _AcRbn = Bricscad.Ribbon;
using _AcLy = Teigha.LayerManager;
using _AcIo = Teigha.Export_Import; //Bricsys specific
using _AcBgl = Bricscad.Global; //Bricsys specific
using _AcQad = Bricscad.Quad; //Bricsys specific
using _AcInt = Bricscad.Internal;
using _AcGc = Bricscad.Geometrical3dConstraints; //Bricsys specific
using _AcPb = Bricscad.Publishing;
using _AcMg = Teigha.ModelerGeometry; //Bricsys specific
using _AcLic = Bricscad.Licensing; //Bricsys specific
using _AcMec = Bricscad.MechanicalComponents; //Bricsys specific
using _AcBim = Bricscad.Bim; //Bricsys specific
using _AcDm = Bricscad.DirectModeling; //Bricsys specific
using _AcIfc = Bricscad.Ifc; //Bricsys specific
using _AcRhn = Bricscad.Rhino; //Bricsys specific
using _AcCiv = Bricscad.Civil; //Bricsys specific
using _AxApp = BricscadApp; //COM
using _AxDb = BricscadDb; //COM
#elif ARX_APP
using _AcAp = Autodesk.AutoCAD.ApplicationServices;
using _AcBr = Autodesk.AutoCAD.BoundaryRepresentation;
using _AcCm = Autodesk.AutoCAD.Colors;
using _AcDb = Autodesk.AutoCAD.DatabaseServices;
using _AcEd = Autodesk.AutoCAD.EditorInput;
using _AcGe = Autodesk.AutoCAD.Geometry;
using _AcGi = Autodesk.AutoCAD.GraphicsInterface;
using _AcGs = Autodesk.AutoCAD.GraphicsSystem;
using _AcGsk = Autodesk.AutoCAD.GraphicsSystem;
using _AcPl = Autodesk.AutoCAD.PlottingServices;
using _AcPb = Autodesk.AutoCAD.Publishing;
using _AcBrx = Autodesk.AutoCAD.Runtime;
using _AcTrx = Autodesk.AutoCAD.Runtime;
using _AcWnd = Autodesk.AutoCAD.Windows; //AcWindows.dll
using _AdWnd = Autodesk.Windows; //AdWindows.dll
using _AcRbn = Autodesk.AutoCAD.Ribbon; //AcWindows.dll
using _AcInt = Autodesk.AutoCAD.Internal;
using _AcLy = Autodesk.AutoCAD.LayerManager;
using _AxApp = Autodesk.AutoCAD.Interop;
using _AxDb = Autodesk.AutoCAD.Interop.Common;
#endif
#If BRX_APP Then
Imports _AcAp = Bricscad.ApplicationServices
Imports _AcBr = Teigha.BoundaryRepresentation
Imports _AcCm = Teigha.Colors
Imports _AcDb = Teigha.DatabaseServices
Imports _AcEd = Bricscad.EditorInput
Imports _AcGe = Teigha.Geometry
Imports _AcGi = Teigha.GraphicsInterface
Imports _AcGs = Teigha.GraphicsSystem
Imports _AcGsk = Bricscad.GraphicsSystem
Imports _AcPl = Bricscad.PlottingServices
Imports _AcBrx = Bricscad.Runtime
Imports _AcTrx = Teigha.Runtime
Imports _AcWnd = Bricscad.Windows
Imports _AdWnd = Bricscad.Windows
Imports _AcRbn = Bricscad.Ribbon
Imports _AcLy = Teigha.LayerManager
Imports _AcIo = Teigha.Export_Import 'BricsCAD specific
Imports _AcBgl = Bricscad.Global 'BricsCAD specific
Imports _AcQad = Bricscad.Quad 'BricsCAD specific
Imports _AcInt = Bricscad.Internal
Imports _AcGc = Bricscad.Geometrical3dConstraints 'BricsCAD specific
Imports _AcPb = Bricscad.Publishing
 Imports _AcMg = Teigha.ModelerGeometry 'BricsCAD specific
 Imports _AcLic = Bricscad.Licensing 'BricsCAD specific
 Imports _AcMec = Bricscad.MechanicalComponents 'BricsCAD specific
 Imports _AcBim = Bricscad.Bim 'BricsCAD specific
 Imports _AcDm = Bricscad.DirectModeling 'BricsCAD specific
 Imports _AcIfc = Bricscad.Ifc 'BricsCAD specific
 Imports _AcRhn = Bricscad.Rhino 'BricsCAD specific
 Imports _AcCiv = Bricscad.Civil 'BricsCAD specific
Imports _AxApp = BricscadApp 'COM
Imports _AxDb = BricscadDb 'COM
#ElseIf ARX_APP Then
Imports _AcAp = Autodesk.AutoCAD.ApplicationServices
Imports _AcBr = Autodesk.AutoCAD.BoundaryRepresentation
Imports _AcCm = Autodesk.AutoCAD.Colors
Imports _AcDb = Autodesk.AutoCAD.DatabaseServices
Imports _AcEd = Autodesk.AutoCAD.EditorInput
Imports _AcGe = Autodesk.AutoCAD.Geometry
Imports _AcGi = Autodesk.AutoCAD.GraphicsInterface
Imports _AcGs = Autodesk.AutoCAD.GraphicsSystem
Imports _AcGsk = Autodesk.AutoCAD.GraphicsSystem
Imports _AcPl = Autodesk.AutoCAD.PlottingServices
Imports _AcPb = Autodesk.AutoCAD.Publishing
Imports _AcBrx = Autodesk.AutoCAD.Runtime
Imports _AcTrx = Autodesk.AutoCAD.Runtime
Imports _AcWnd = Autodesk.AutoCAD.Windows 'AcWindows.dll
Imports _AdWnd = Autodesk.Windows 'AdWindows.dll
Imports _AcRbn = Autodesk.AutoCAD.Ribbon 'AcWindows.dll
Imports _AcInt = Autodesk.AutoCAD.Internal
Imports _AcLy = Autodesk.AutoCAD.LayerManager
Imports _AxApp = Autodesk.AutoCAD.Interop
Imports _AxDb = Autodesk.AutoCAD.Interop.Common
#End If
Known issues
After creating a new database entity, it is good practice to immediately call SetDatabaseDefaults() on the new entity so that it has valid initial state before setting properties or calling methods.
© Bricsys NV. All rights reserved. |
