vl-file-delete
(vl-file-delete fileName)
This function deletes the specified
file fileName.
Arguments |
fileName (string) name of the file to be deleted |
Return |
T if the file was successfully deleted, NIL in case of an error |
Example |
Remarks |
if fileName does not contain a path, the actual OS folder is used to search for the file |
