vl-file-rename
(vl-file-rename oldName newName)
This function renames the file
oldName to a new
name newName.
Arguments |
oldName (string) specifies the existing file; if no path is
included, the file is searched in the current OS folder |
Return |
T if renaming succeeded, NIL in case of an error |
Example |
Remarks |
if a file with name newName does already exist, the function will fail |
