vl-file-systime
(vl-file-systime fileName)
This function returns the date + time of last
modification of file fileName.
Arguments |
fileName (string) name of an existing file; if no path is included, the file is searched in the current OS folder |
Return |
(list) a list in format
Example |
(vl-file-systime (findfile "bricscad.exe")) (2019 10 4 24 4 1 10 0) |
Remarks |
