vl-filename-base
(vl-filename-base fileName)
This function returns the name of the
file fileName, without path and extension.
Arguments |
fileName (string) a file name, optionally containing path and/or extension |
Return |
(string) the name of the file, without path specification and extension |
Example |
(vl-filename-base "C:/MyFolder/MyFile.txt") "MyFile" |
Remarks |
