vl-some
(vl-some comparator [ listA [ listB ... ] ]
This function verifies all corresponding items
from listA against those from listB (and further lists)
using the comparator function.
Arguments |
comparator
(symbol, function, lambda) function used
for the boolean comparison; must return NIL resp.
non-NIL |
Return |
the last result of comparator function call, or NIL |
Example |
(vl-some '= '(1 2 5 8 9) '(2 3 5 6 7)) returns T (number 5 is in both lists, at same position) |
Remarks |
passes the 1st item of listA, and the 1st item of listB (and so on) to the comparator function, then the 2nd item of listA and the 2nd item of listB (and so on), until a comparison returns non-NIL |
