vl-unload-vlx
(vl-unload-vlx appName)
This function removes all function definitions
of a loaded NameSpace-enabled application appName.
Arguments |
appName (string) the name of a VLX compiled application |
Return |
T is all functions from appName were successfully removed (set as NIL) |
Example |
Remarks |
the "application name" is the
file name without path and extension; |
