vl-vplayer-set-linetype
(vl-vplayer-set-linetype layer
viewport linetype)
This function sets the viewport-specific
linetype override
for the layer.
(layer
can specify one or more layers)
Arguments |
layer specifies one or more layer(s) to apply the
viewport-specific linetype |
Return |
T if the linetype value is successfully applied resp. removed, NIL otherwise |
Example |
Remarks |
this is a BricsCAD-specific function ! |
