vlax-curve-getparamatdist
(vlax-curve-getparamatdist curveEnt
dist)
This function returns the parameter on
the curveEnt curve entity at specified dist distance.
Arguments |
curveEnt (ename or vla-object) the COM object of any "curve"
entity |
Return |
double; the parameter of the curve at the specified distance (relative to the curve start point) or NIL |
Example |
(setq vlaCircle
(vlax-ename->vla-object (entlast))) #<VLA-OBJECT
IAcadCircle 000000003A012150> |
Remarks |
