vlax-get-or-create-object
(vlax-get-or-create-object COM-Id)
This function returns an existing instance of
the COM server object identified by COM-Id or creates a new
instance if the COM server is actually not running.
Arguments |
COM-Id (string) identifies the COM server object by its name |
Return |
VLA-OBJECT; the COM server object, or NIL if instantiation fails |
Example |
(setq fso
"Scripting.FileSystemObject")) |
Remarks |
this function tries to first
connect to an existing instance of the specified COM server
object; |
