vlax-variant-change-type
(vlax-variant-change-type variantVar
toType)
This function returns the provided
variantVar with
the data value converted into toType.
Arguments
variantVar
(Variant) the COM Variant
toType (integer) the target type of the
variantVar
can be one of the following :
vlax-vbEmpty 0 uninitialised
data
vlax-vbNull 1 empty
data
vlax-vbInteger 2 short Integer (16
bit)
vlax-vbLong 3 long integer (32
bit)
vlax-vbSingle 4 float-point number
(single precision)
vlax-vbDouble 5 double-point
number (double precision)
vlax-vbString 8 string
vlax-vbObject 9 VLA-Object
vlax-vbBoolean 11
boolean
vlax-vbVariant 12 variant
vlax-vbArray 8192
SafeArray
Return
returns a variant with new
data type (and converted data value)
Example
(setq var (vlax-make-variant
3.12)) #<variant 5 3>
(setq var (vlax-variant-change-type var
vlax-vbString)) #<variant 8 3.12>
(vlax-variant-value var) "3.12"
Remarks
