vlax-write-enabled-p
(vlax-write-enabled-p vlaObject)
This function verifies whether vlaObject is
actually write-enabled.
Arguments |
vlaObject (VLA-Object) any COM object |
Return |
T if the object is write-enabled, NIL otherwise (i.e. object is erased, or only open for read access) |
Example |
Remarks |
if the object is "write-enabled", it can be modified (otherwise any modification will trigger an error) |
