vlr-command-reactor
(vlr-command-reactor customData
callbackList)
This function creates and attaches a Command
reactor to the current drawing, for the command events specified
by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-commandWillStart
a command is about to
start
:vlr-commandEnded
a command has ended
:vlr-commandCancelled
a command was
cancelled
:vlr-commandFailed
a command failed to properly
complete
:vlr-unknownCommand
an unknown command name was
entered, failed to start
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
command reactor object - #<VLR-Command-Reactor>
args : (list)
contains 1 element (string), which is the command name, always
uppercase
Return
the reactor object
#<VLR-Command-Reactor> or NIL
Example
Remarks
