vlr-insert-reactor
(vlr-insert-reactor customData
callbackList)
This function creates and attaches a Insert
operation reactor to the current drawing, for the command events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-beginInsert
a block is about to be
inserted
:vlr-beginInsertM
inserted, using a 3D transformation matrix
:vlr-otherInsert
inserted; intermediate event, before ObjectId translation will
happen
:vlr-endInsert
a block insertion operation
has been finished
:vlr-abortInsert
has been aborted
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
insert reactor object - #<VLR-Insert-Reactor>
args : (list)
contains 1...3 arguments, depending on the particular event
:vlr-endInsert
:vlr-abortInsert
1 argument
(VLA-Object)
the database in operation
:vlr-otherInsert
2 arguments
1st argument : (VLA-Object) the database in
operation
2nd argument : (VLA-Object) the source
:vlr-beginInsert
3 arguments
operation
2nd argument : (string) name of the block
being inserted
3rd argument : (VLA-Object) the source
:vlr-beginInsertM
3 arguments
operation
2nd argument : (list) 3D transformation
matrix
Return
the reactor object
#<VLR-Insert-Reactor> or NIL
Example
Remarks
