vlr-miscellaneous-reactor
(vlr-miscellaneous-reactor customData
callbackList)
This function creates and attaches a
Miscellaneous operation reactor to the current drawing, for the
command events specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-pickfirstModified
the PickFirst SelectionSet
has changed
:vlr-layoutSwitched
the active layout has
changed
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
miscellaneous reactor object -
#<VLR-Miscellaneous-Reactor>
args : (list)
contains 0...1 arguments, depending on the particular event
0 arguments
:vlr-layoutSwitched
1 argument :
(string)
the name of the new current layout
Return
the reactor object
#<VLR-Miscellaneous-Reactor> or NIL
Example
Remarks
