vlr-remove-all
(vlr-remove-all [ reactorType ] )
This function disables all reactors of
specified reactorType.
Arguments
reactorType
(reactor type, optional) the type
of reactors to be disabled; if omitted or NIL, all reactive
reactors are disabled;
can be one of these reactor types (or NIL)
:VLR-AcDb-Reactor
:VLR-Command-Reactor
:VLR-DeepClone-Reactor
:VLR-DocManager-Reactor
:VLR-DWG-Reactor
:VLR-DXF-Reactor
:VLR-Editor-Reactor
:VLR-Insert-Reactor
:VLR-Linker-Reactor
:VLR-Lisp-Reactor
:VLR-Miscellaneous-Reactor
:VLR-Mouse-Reactor
:VLR-Object-Reactor
:VLR-SysVar-Reactor
:VLR-Toolbar-Reactor
:VLR-Undo-Reactor
:VLR-Wblock-Reactor
:VLR-Window-Reactor
:VLR-XREF-Reactor
Return
returns a list of sub-lists
using the format :
( (reactorType reactor1 reactor2 ...)
(reactorType reactor1 reactor2 ...) ...)
specifying all reactors that were
disabled
Example
(vlr-remove-all)
disables all active reactors, returns
(:VLR-AcDb-Reactor #<VLR-AcDb-Reactor>
#<VLR-AcDb-Reactor>)
(:VLR-Command-Reactor
#<VLR-Command-Reactor>)
Remarks
see (vlr-add) and
(vlr-added-p)
and (vlr-remove) functions
