vlr-type
(vlr-type reactor)
This function verifies the type of the
specified reactor.
Arguments
reactor (any reactor object) the reactor to
query
Return
symbol; the type of
the reactor object, can be one of :
:VLR-AcDb-Reactor
database reactor
:VLR-Command-Reactor
command reactor
:VLR-DeepClone-Reactor
deepclone reactor (cloning in
same database)
:VLR-DocManager-Reactor
document manager
reactor
:VLR-DWG-Reactor
drawing reactor
:VLR-DXF-Reactor
DXF operation reactor
:VLR-Editor-Reactor
CAD editor reactor
:VLR-Insert-Reactor
insert operation
reactor
:VLR-Linker-Reactor
BRX module loader
reactor
:VLR-Lisp-Reactor
Lisp events reactor
:VLR-Miscellaneous-Reactor
reactor covering several
other events + operations
:VLR-Mouse-Reactor
mouse event reactor
:VLR-Object-Reactor
object + entity operation
reactor
:VLR-SysVar-Reactor
system variables
reactor
:VLR-Toolbar-Reactor
toolbar operation
reactor
:VLR-Undo-Reactor
undo operation reactor
:VLR-Wblock-Reactor
wblockclone reactor (cloning
between different databases)
:VLR-Window-Reactor
window operation
reactor
:VLR-XREF-Reactor
xref operation reactor
Example
(setq rx (vlr-object-reactor
nil nil '((:vlr-modified . cb))))
#<VLR-Object-Reactor>
(vlr-type rx) :VLR-OBJECT-REACTOR
Remarks
see (vlr-types) function
