vlr-undo-reactor
(vlr-undo-reactor customData
callbackList)
This function creates and attaches a Undo
command reactor to the current drawing, for the command events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-undoSubcommandAuto
Undo option "Auto" has been
processed
:vlr-undoSubcommandControl
Undo option "Control" has
been processed
:vlr-undoSubcommandBegin
Undo option "Begin" (or
"Group") is about to be processed
:vlr-undoSubcommandEnd
Undo option "End" is about to
be processed
:vlr-undoSubcommandMark
Undo option "Mark" is about
to be processed
:vlr-undoSubcommandBack
Undo option "Back" is about
to be processed
:vlr-undoSubcommandNumber
Undo option "Number" is about
to be processed
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the undo
reactor object - #<VLR-Undo-Reactor>
args : (list)
contains 1 or more arguments depending on the particular event
1 argument
(integer) status
integer value is always 0, indicates
"operation is about to start"
2 arguments
1st argument : (integer) status, always 4,
indicates "operation finished"
2nd argument : (symbol) T/NIL - T indicates
"Auto" is ON, NIL indicates OFF
2 arguments
2nd argument : (integer) "Control" option
0=None 1=One 2=All
2 arguments
1st argument (integer) status, always 0,
indicates "operation is about to start"
2nd argument (integer) number of undo staps to
be undone
Return
the reactor object
#<VLR-Undo-Reactor> or NIL
Example
Remarks
